shaft spacers
hey guys before I go to the dragon the dragon I'd like to install shaft spacers. being from Kitchener none of the shops around here stock any.
can u think of any shop in the GTA that would have these in stock? I tried teknotic. he has to order them. I only have 3 weeks. so ordering them might be out of the question cheers Russ |
eBay
eBay
I would say get two piece ones otherwise you may as well just swap axle buckets- which is free and requires no added parts |
Are these things necessary?
I've had my car lowered for 4 years and done nearly 50k on the same axles. No vibrations or weird things to report here. |
If you lower your car and you don't get vibrations then you don't need spacers. If you get vibrations, spacers simply move the wear spot to a new location, same thing as swapping buckets.
Originally Posted by fernando.
(Post 23540700)
ive been lowered 25000km. I was just trying to fix any issues that might happen to or from the dragon.
and I don't currently have any vibration |
Originally Posted by blwnb16a
(Post 23540973)
and I don't currently have any vibration If by slight chance you do develop a vibration it is not a mechanical issue that needs immediate attention, as it won't lead to a mechanical breakdown situation. You could make it back home to address the issue without a problem. |
Just make sure your brakes are good to go. A good dot 4 fluid.
Lowering the car moves the axle knuckle further out of the buckets. Adding the spacer just puts the axle back to where it was before lowering.
