shaft spacers
shaft spacers
hey guys before I go to the dragon the dragon I'd like to install shaft spacers. being from Kitchener none of the shops around here stock any.
can u think of any shop in the GTA that would have these in stock? I tried teknotic. he has to order them. I only have 3 weeks. so ordering them might be out of the question
cheers Russ
cheers Russ
If you lower your car and you don't get vibrations then you don't need spacers. If you get vibrations, spacers simply move the wear spot to a new location, same thing as swapping buckets.
If by slight chance you do develop a vibration it is not a mechanical issue that needs immediate attention, as it won't lead to a mechanical breakdown situation. You could make it back home to address the issue without a problem.
