Tire shops in GTA
Any recommendations? Can I get a better deal then the list? Tks!
Best one i've found is tires23 AP1 wheels, +1 sizing, prices tax inc. $580 for Kuhmo 712s $920 or so for Bridgestone RE-70s |
you will prob get the best deal there...the only places I have checked with can just barely match his pricing, and tire23 will usually install for you too.
otherwise you can try steelcase tire in markham or wheels direct in scarborough...sorry i dont know any west end places. on a side note - i suggest not buying kumho 712's....yes i know they're cheap and so called "best bang for the buck" tire, but they are shit....ive used them for over a year on a higher HP car of mine and they were sad. i would suggest toyo t1-s or falken rt-615 or advan neova's if u can afford them (all around the same prices) and destroy the 712. of course the usual high end BFgoodrich or michelin or bridgestone is a solid choice if u have even more money to spend. even the yoko es100 is a solid tire tho its a "medium sport perf" tire, as would be the dunlop sp9000 (i think) or something from pirelli (not a big fan of their car tires unless its a P-Zero or a bike tire :LOL: ... ) |
If you do not use the oem spec S-02s you should find a replacement that either has the same contact patch size (8"ish) or is 245/45/16? The 225/50/16 Neovas have a contact patch that is about the same, does that mean they are suitable to replace the oem s-02s? |
Hankook RS-2 is solid as well.
Tires 23 is the BEST! Martin is your man!
Originally Posted by evolution' date='Mar 22 2007, 01:46 PM
Thanks. I read through the the stickied threads in the wheel section, is this understanding correct?
If you do not use the oem spec S-02s you should find a replacement that either has the same contact patch size (8"ish) or is 245/45/16? The 225/50/16 Neovas have a contact patch that is about the same, does that mean they are suitable to replace the oem s-02s? Front = 205/55/16 You can sub the 205/55/16 for 215/50/16 (if you can find sizing). Not advised to use 225/50/16 on the rear, you will get extra oversteer. |
Originally Posted by iDomN8U' date='Mar 23 2007, 01:18 PM
Rear = 245/46/16
Front = 205/55/16 |
I got the most shocking deal and incredible service at Tirecraft out by the airport.
call Jeff Wenzel 905.760.1130 tell him that dave with the nsx recommeneded him...ILL DO ANYTHING TO GET THAT PRICE AGAIN!!!!!! |
only thoughts on the rt-615s is the tire noise... compared to the s02s, they are loud.. (especially if you are on the highway a lot).. that would be my only real complaint about them.
