JS2k Custom Headlight Modding Services- Clear Reflectors, Quad Projectors, Demon Eyes
JS2k is proud to present our Custom Headlight Modification Services!
Want a completely custom headlight for style or brightness? Stand out from any other S2000!
Clear Diffusers / Installation
We perform custom installation services for our clear diffusers with a quick 2 day turnaround.
S2000 owners love our cleared headlights, but some may not want to bake their headlights. We'll do it for you!
What Do We Do?
Ordering
JS2k Clear Diffusers Professional Installation! - $249.99 : JS2K.com!
Product Info:
JS2k.com is the only place to get clear diffusers, also called clear corners, to clear out your headlights for AP1s and AP2s. These replacement headlight reflector pieces were carefully replicated from a JDM AP1 and an AP2 and recreated in clear!
Options:
AP1 Clear
AP1 Smoked
AP2 Clear
JS2k Quad Projectors - Retrofitting a Bi-Xenon projector in place of the high beams
JS2k.com proudly presents a radical new headlight modification to give you the brightest driving experience without blinding oncoming traffic: JS2k Quads! - S2000 Bi-Xenon Projector Custom Retrofit.
What Does This Do?
This custom turnkey retrofit will involve fitting a bi-xenon projector into your existing headlights in the high beam reflector bowl.
Low Beams
When you turn on your low beams, you’ll be greeted with FOUR low beam lights that have an unparalleled brightness below the cutoff.
High Beams
Need more light? Turn on your high beams! The new projectors will magnetically trigger the cutoff to be hidden, allowing the light to go above the cutoff, giving you a ton of light to see down the road. All the while, your factory S2000 projectors will still be illuminated for light under the cutoff.
Ordering
JS2k Quad Projectors! - S2000 Bi-Xenon Projector Conversion - $399.99 : JS2K.com!
What Do We Do?
Customizations
We can make the following customizations as part of your project:
Stealth look:
JS2k Demon Eyes - Add Color Changing LEDs inside your projectors
Want some added style for your headlights? We’ll retrofit color changing LEDs inside the projectors to give your headlights a meaner look. Download our app, and you’ll be able to control the color and pattern to whatever your mood desires or to match the color of your car. These can be added as a pair to the factory projectors and / or the high beam projectors.
Ordering
JS2k Demon Eyes! - Color Changing LEDs inside OEM Projectors - $199.99 : JS2K.com!
What Do We Do?
What Do We Do?
We’ll carefully disassemble your headlights, install the diffusers, seal the headlight, and ship them back to you. All you’ll need to do is plug them back in!
This service includes the labor, parts (including the diffusers), and return shipping. Just send us your headlights with whatever method you'd prefer, we'll mod them, and send them back to you.
Ordering
Product Info:
Options:
AP1 Clear
AP1 Smoked
AP2 Clear
What Does This Do?
Low Beams
High Beams
Ordering
What Do We Do?
We’ll carefully disassemble your headlights, install the projectors, aim the projectors, install the HIDs for the second projector, wire the projectors, seal the headlight, and ship them back to you. All you’ll need to do is plug them in to your factory harnesses.
This service includes the labor, parts, and return shipping. Just send us your headlights with whatever method you'd prefer, we'll mod them, and send them back to you.
Turnaround time once the headlights have been received is 3 days.
Customizations
Stealth look:
- Painted high beam reflector housing (as shown in the images)
- Painted projector body (as shown in the images)
- Painted projector shroud (as shown in the images)
- Painted high beam reflector housing (as shown in the images) - This will make the projectors stand out
- Silver finished projector body
- Silver finished projector shroud
Ordering
What Do We Do?
We’ll carefully disassemble your headlights, install the demon eye LEDs, wire the projectors lights, seal the headlight, and ship them back to you. Install the headlights, and wire the demon eyes to a switch.
__________________
AP1 and AP2 Clear Headlight Diffusers!!! - Clear out your S2000 headlights!
LED Conversions for all S2000 lights
Keyhole Covers - Get the Shaved look
Oil Drain Valve - Easiest Oil Change ever!
_________
For LEDs for your other cars, head to our new website: SupernovaLEDs.com. Same great quality, easy-to-use website. Pick your car, we'll show you what fits.
_________
