Sale on S2000 Coolant overflow tanks and oil catch cans!
We are having a Sale on the AB-Speed S2000 coolant overflow tanks as well as the S2000 oil catch can/coolant overflow combo tanks through the end of April.
$15 off the coolant overflow tanks
$25 of the oil catch can combo tanks
Price for the S2000 coolant overflow tank will be $134.99 plus shipping
http://shop.moddiction.com/AB-Speed-...w-tank-015.htm
Oil catch can combo tank will be $325 shipped!
http://shop.moddiction.com/AB-Speed-...-combo-016.htm
Info on combo tank:
AB-Speed S2000 oil catch can/coolant overflow combo
-100% aluminum construction.
-Hand made in USA.
-Tig Welded.
-Internally divided keeping coolant and blow by oil separate.
-Aluminum L tube and cnc machined billet aluminum cap on coolant side, performs the same as the stock plastic unit.
-Oil catch side features 1.5" I.D. breather filter (included)
-Internally baffled to aid in air/oil separation.
-Two -10AN fittings welded in for attaching hoses.
-Powdercoating available.
-Optional fluid fill level indicator.
-Oil drain valve.
-Lifetime Guarantee on Aluminum Parts and construction.
-Drilling required for installation.
-Cruise control must be relocated for installation.
-Hoses and fittings for valve cover are not included with catch can/overflow tank.
Info on the Coolant overflow tank:
- 100% hand made in USA
- TIG welded aluminum construction
- Billet aluminum machined one-piece cap
- Steel tube that extends to near the bottom of the tank to perform identical to the stock system
- Drop into stock Cruise Control bracket(Plug and Play), or bolt in design available(bolt in design requires drilling)
- Optional fluid fill level indicator
- Lifetime Guarantee on aluminum tank
Below are some pictures of both the oil catch can combo tank and the Plug and Play coolant overflow tank.(Please note. Site glass is $15 extra. Shown with older style site glass and fittings)
Info on combo tank:
-Hand made in USA.
-Tig Welded.
-Oil drain valve.
Moddiction
97
Apr 22, 2016 05:35 AM
Moddiction
Apr 11, 2011 03:18 PM
