AB-Speed S2000 Oil catch can/coolant overflow tank
Former Sponsor
I am now offering AB-Speed S2000 Oil catch can/Coolant overflow combo tanks on moddiction.com
Best quality and price out there!
To order please click here to order
http://shop.moddiction.com/Honda-S20...m1plqscsfapp02
Here is some information on them.
-100% aluminum construction.
-Hand made in USA.
-Tig Welded.
-Internally divided keeping coolant and blow by oil separate.
-Aluminum L tube and cnc machined billet aluminum cap on coolant side, performs the same as the stock plastic unit.
-Oil catch side features 1.5" I.D. breather filter (included)
-Internally baffled to aid in air/oil separation.
-Two -10AN fittings welded in for attaching hoses.
-Powdercoating available.
-Optional fluid fill level indicator.
-Oil drain valve.
-Lifetime Guarantee on Aluminum Parts and construction.
-Drilling required for installation.
-Cruise control must be relocated for installation.
-Hoses and fittings for valve cover are not included with catch can/overflow tank.
-This item may ship direct from manufacturer.
FREE SHIPPING to the US only!
For other Countries please contact us before placing order.
On to the pictures.
-Hand made in USA.
-Tig Welded.
-Oil drain valve.
On to the pictures.
Former Sponsor
To remove oil vapors from the air going to the intake. On the track with hard sweeping turns oil can go to intake causing big puff of smoke. This prevents that and collects the oil in the catch can. Great mod to have if boosted as well to vent the crankcase and separate the oil from the air. The catch can being baffled helps collect the oil more efficiently.
Wow nice piece of engine bling...would like to get one, but I was a little shocked it doesn't come with the hoses What all do you need to install this, does it come with a bracket to relocate the CC?
Former Sponsor
These don't come with a bracket to relocate the CC. For the hoses it depends how you would like to set it up. Can be set up to work with existing lines off the valve cover or can do it with 10-AN lines drilled into the valve cover for maximum venting. Can be made with whichever type of lines you want to run to it.
