Tampa Gulf coast and surrounding areas...there be pirates here!!
check engine light ordeal
Old Nov 20, 2008 | 04:25 PM
Elroy's Avatar
Originally Posted by JUSTINTHECOASTIE,Nov 20 2008, 01:09 PM
whats a map whack????
Whack the Map sensor!
1. Unplug the MAP sensor.
2. Strike it with a rubber handled screw driver or similar. (Not to hard a couple
of times).
3. Plug it up again.
You may wnt to reset the ecu also but not necessary.
J
Old Nov 20, 2008 | 05:44 PM
Metcalfe's Avatar
Had this problem with a car in the shop... It is probable that your valves need to be adjusted. Thats what fixed this car... we also replaced the injectors which is also another known cause of this. Get in contact with me via pm if you wanna swing by the shop (LHT Performance)
Old Nov 22, 2008 | 01:00 PM
JUSTINTHECOASTIE's Avatar
sweet bro thanks, Ima be gettin n touch with you soon, I have another surgery on my ACL on tuesday nov 25 so around mid december if not earlier we'll meet thanks man
Old Nov 22, 2008 | 08:20 PM
Metcalfe's Avatar
No prob..
Old Nov 24, 2008 | 08:59 AM
dezignpro04's Avatar
+1 for the right plugs and +2 for a MAP whack.
The OEM NGK is: PFR7G-11S
Here is some pricing...
Honda wants: $27.99 x 4 = $111.96
NAPA wants: $12.99 x 4 = $51.96
Advance wants: $10.00 x 4 = $40.00
Hope that helps.
Old Nov 24, 2008 | 12:56 PM
2big4aS2000's Avatar
problem is almost no one stocks those plugs - they will order them in for you, so just call ahead and save a trip.
Old Nov 24, 2008 | 01:21 PM
WoodyfromGA912's Avatar
Where's the map sensor? other's said it could be the crank sensor, again where are they????
Old Nov 24, 2008 | 01:49 PM
JohnsS2000's Avatar
If you go to an autopart store find out the corect plug you are goin to get and tell them the plug type and number . I strongly recommend that you NOT tell the type of car or give an address . This is yet anothe way some theives are geting to the locations of your prize seats , this is a method used in the past . FYI .
DragonMahn
Aug 21, 2012 12:01 AM
k00kaine
Oct 26, 2010 05:29 AM
1needaS2K
Jul 8, 2009 02:53 PM
johev
Jul 25, 2002 05:19 PM
