Suspension install/Alignment shop?
Hey guys, I have a s2000 im installing ground control/koni set up with t1r halfshaft spacers, I dont have the time or the tools to do it myself and am looking for a reputable shop.
Would need:
Install
Height adjust
Alignment
Thanks
*What should something like this cost?
I have done 3 or 4 suspension installs on integras in the past but have never had to deal with the coilover aspect of perfectly adjusting the height. also no time
Would need:
Install
Height adjust
Alignment
Thanks
Here's some more info.
Address S & R Performance
9507A N Trask
Tampa,FL 33624
www.sandrperformance.com
9507A N Trask
Tampa,FL 33624
Like Raven stated - S&R
Bobby knows the S suspension very well, here is my weighted corner balance and alignment: https://www.s2ki.com/forums/index.php?showt...&#entry12204361
J
J
9507A N Trask
Tampa,FL 33624
9507A N Trask
Tampa,FL 33624
Don't forget to let the new springs settle for a couple weeks / couple hundred miles before getting corner balanced. And setting the ride height at installation is not difficult...but realize that as the springs settle the ride height will change.
You might see if Dave & Puddy can install the coilovers and spacers for you. Not sure what they would charge, but their shop is more of a side business than their normal gig (and s2kPuddydad is a site sponsor). Then go to S&R after the springs have settled for a corner balance.
