What is it called?
What is the piece of plastic that is like a little windshield that is in the interior on top of the secret compartment in my S2000? also where might i be able to find a replacement one. thinking of having one etched or reverse painted but want a stock backup
I believe the item you are referring to is the wind screen. It is made of clear plexiglas in a black plastic base that is mounted with 2 screws onto the top of the secret compartment lid.
Obviously you can order a replacement from the Honda dealer however this will be an expensive item, most likely upwards of $250 for the entire assembly (plexi screen and the frame). There are a couple for folks who offer just the plexi and in the stock OEM size or larger to block more air flow and or give you a larger area for a decal or etching. Ricks Accessories offers them: http://www.ricks2k.com/products/aero.php
If you want something unique try this: http://www.kingpennindustries.com/Wi...il.aspx?wrid=7
Custom etched and illuminated, pretty cool and pricey.
Try the for sale section of you are looking for a spare OEM, you should be able to find one there at a reasonable price.
Good Luck!
Good Luck!
JS2k.com
161
Sep 11, 2013 10:20 PM
