F it I'm Going
I dont' know what to do. Im pretty sure I can't get a refund on the rooms. and pretty sure can't get a refund on the WTD expenses. Plus Chris said to just keep an eye on it at the Dragon, and get it fixed when I get home.
I I may bring a jack, towel, 23mm Wrench, and a bottle of fluid and keep an eye on it.
yea, its not hard to put fluid in the diff if you have a pump or a tube to attatch to fill it if you can keep an eye on it. The suck part is there is no dipstick type of thing to check it other than just opening the fill bolt and seeing if its topped off or not.
Well xviper said that he has ran with an extra 100-150cc in the diff with out any problems....now I wouldn't normally do that, but under the circumstances I may risk it. Plus HTG will be there and I can talk with him about it while I'm there.
I also called airgate, and no refund already too late (I figured that just wanted to make sure) and Im not going to cancel my room b/c Todd will be fuct.
So as of this moment Im still in.
unless someone buys my spot then Ill just take about a $100 hit vs $200
