Front grille inserts
Old Feb 19, 2007 | 12:41 PM
matthouston23's Avatar
Default Front grille inserts
Grille Inserts
I saw these and wanted to get opinions before I bought them. Good, bad, or ugly?
If good, are these in particular or should I get them somewhere else?
Any opinions appreciated.
Old Feb 19, 2007 | 02:56 PM
caneintn's Avatar
I have the coastal metal ones. I got them used for about $75.
The low cost on these worry me. I would ask what gauge or thickness the metal is. To flimsy and they will damage easily.
Also realize this is purely a "looks" mod as it actually will decrease air flow to your radiator.
Old Feb 19, 2007 | 04:50 PM
Thanks. Do you have to remove the bumper to install?
Old Feb 20, 2007 | 07:08 AM
caneintn's Avatar
You do not but it makes it easier if you do. You will need to cut out the two side vents. I did this with a dremmel. I left my main center structure in for added support.
Old Feb 20, 2007 | 09:23 AM
Have you had any problems with the reduction in air flow?
Old Feb 20, 2007 | 10:25 AM
caneintn's Avatar
Not that I can tell. I saw a thread where there is a comparison of the airflow for all different options. The reduction in airflow was about 15%. It may make more of a difference for those with sc's or turbos. I am just n/a with a comptech cai.
Old Feb 23, 2007 | 02:27 PM
I just received the coastal metals black center grill and installed it. You can barely tell it's there. I like it
Old Feb 23, 2007 | 02:41 PM
Dark_Sub_Rosa's Avatar
Personally I'm not a big fan of grill inserts.
Old Feb 23, 2007 | 02:45 PM
The black ones are real subtle.
Old Feb 23, 2007 | 04:09 PM
nj2tn's Avatar
Yea, I like the ones that are like that. Just enough to make a difference but not draw attention to it specifically.
