Off Balance?
Hello everyone...quick question.
About 2 months ago i had a blow out on my rear left tire. And i replaced it with another brand. Differnt than the original hankook rs-2's. The tires not bad at all, but my question is at speeds under 70mph, the car wont shake. anything 70+ the car shakes...and it all happend after this tire was installed. Do u think its not balanced properly? thanks....
It is because you have a different brand tire installed. The only way you are going to rid yourself of that problem is to get a like (meaning exact same tire as before) tire put on.
More than likely you'll have to get two tires that match. Differences in width and tread depth could cause this. Also it's been pretty cold so you may want to check your tire pressure to make sure they're the same as that may cause it too.
