OFF TOPIC VI
Old May 9, 2007 | 03:00 PM
  #301
NVMY4N's Avatar
hmmmm, the aftermarkets usually have the sticky weights on the inside of the wheels......
they can fly off.
but if they are there...then
Tire Pressure?
Like you said Lugs tight?
Bent Rim
Old May 9, 2007 | 03:02 PM
  #302
matthouston23's Avatar
Checked TP yesterday and it was fine. It does have the sticky weights but there's no evidence that any are missing. Each wheel has an inner and outer weight.
I know the lugs are tight, but I'm not sure if they're the same torque on all 5. Kinda hard to believe that could cause this much vibration though.
Old May 9, 2007 | 03:07 PM
  #303
NVMY4N's Avatar
you got me.
  #304
Spa_Ap1's Avatar
Inner CV joint maybe. I think there was a TSB on AP1's with them wearing out. There's a DIY on swapping them side to side for a temp fix.
Old May 9, 2007 | 03:19 PM
  #305
NVMY4N's Avatar
didn't know that
Old May 9, 2007 | 03:32 PM
  #306
Luckily I've still got my old tires/wheels so I can eliminate a whole bunch of possibilities by swapping those out.
Old May 9, 2007 | 04:02 PM
  #307
Dark_Sub_Rosa's Avatar
Inner CV's would most definitely make it ride like that if they are going out.....
Old May 9, 2007 | 04:06 PM
  #308
nj2tn's Avatar
What could cause that ? I've had a similar issue but I think mine was due to a thrown weight...however I don't want to rule anything out. Mine drives fine until I hit around 70 mph +
Old May 9, 2007 | 04:32 PM
  #309
RBC3's Avatar
Link to TSB?
Old May 9, 2007 | 05:10 PM
  #310
Slows2k's Avatar
If the vibration started after changed wheels/tires it's the wheels/tires.
If the vibration goes away under decel and reoccurs under accel it's inner CV joints.
