What is the ideal alignment specs?
Old Nov 22, 2005 | 08:19 AM
Liquidsation's Avatar
Default What is the ideal alignment specs?
By ideal I mean best all around settings for street and around town. My set up is BBS LM wheels ( front 17 x 7.5 and rear 17 x 8.5) with H&R Sport springs. I just put on two rears and need to get alignment. Do I just have them put with factory specs or is there a better solution?
Thanks,
Rob
Old Nov 22, 2005 | 08:36 AM
ImportSport's Avatar
There are two ideal options outside of OEM spec. One is the common AutoX spec and the other is the Euro Spec. I dont have access to either atm but if you search they should come up.
I would go for the Euro spec if you just plan to street the car. I'm running the AutoX specs and my front camber wear is silly. But I love the handling.
Old Nov 22, 2005 | 11:21 AM
OK. That was a lot of searching. Here is what I found and tell me if this is correct.
Front Camber is -1 degree 00"
Front Caster is 6 degrees 45"
Front Toe is 0 degree 00"
Front Total Toe is 0 degree 00"
Rear Camber is -2 degree 00"
Rear Toe is 0 degree 0"
Rear Total Toe In is 0 degree 40"
Old Nov 22, 2005 | 10:08 PM
Dark_Sub_Rosa's Avatar
That is the Euro spec yes...
I ran the Euro spec on my Volks
Old Nov 23, 2005 | 04:46 AM
Thanks guys!!!!!!!!!!
Black_AP1
Apr 20, 2016 06:37 AM
gofast182
31
Jul 17, 2012 06:52 AM
SPLNDID
Mar 14, 2010 02:19 PM
onani
Nov 23, 2005 03:23 PM
MyS2KGoSlow
Aug 23, 2005 04:32 AM
