Eibach Front sway bar review
I went to Inline Racing yesterday and Matt installed my Eibach front sway bar among some other things. He requested a review so here it is:
Previous setup: Tein coilovers 12kg/mm front, 10kg/mm rear 17x9 +63 wheels with 255/40/17 RS3's front and rear rear toe control arms apr gtc 200 wing Alignment: 2deg camber front, 2.5 deg rear, max allowed caster, 0 toe front, almost 0 toe in rear The car had very good rotation at slow speeds, was pretty balanced at medium speed turns and very very stable at high speed and would push quite a bit-the wing did its job The problem was that when entering a corner a little too fast the tail would come right out. To counter the high speed push i got a splitter but its not installed yet, and to counter the scary oversteer I got the eibach front sway bar. the swaybar was recommended by my instructor HPD, Thanks Andrea. The bar is set on the stiff setting. My initial impressions after a day of driving and purposefully pushing the car to the limit upon every possible occation I must say that this is a great investment for similarly setup cars. Here is what I was able to notice Pros: The car reacts much faster to steering inputs Roll is significantly reduced. It feels almost flat I can get on the throttle much earlier Greater stability Cons: There is a slight weight gain at the front axle, probably 4-5lbs increase compared to stock ap1 bar Rougher ride on uneven shitty houston streets I will add my track impressions soon. Thanks again to Matt for the install and Andrea for the recommendation UPDATE: My track experience with this bar: So I atttended Drivers Edge at MSR Houston this weekend. The only change to my setup since last time I was here 2 months ago was the sway bar. The car felt ALOT less twitchy, much more controlable and my confidence was all the way up there. I was able to get on the throttle much sooner at diamonds edge and after the launch. The car also felt much more stable through the carousel. |
Thanks for the review buddy, hopefully this picks up more on this forum
i always try to review everything. it really helps everybody if you think about how many hours you spend everytime you are considering a new mod.
nice review.
thanks for these reviews! :thumbup: :thumbup: :thumbup:
track experience added to the original post
Very nice job Thanasis. I had to let him pass me a couple of times hehe
Glad y'all made it out there, I was stuck on the wait list :(
I'll see y'all out at TWS! Thanasis, I'll have the exhaust and sways on by then, I ended up buying the front sway as well. |
Originally Posted by jellis01
(Post 22476240)
I'll see y'all out at TWS! Thanasis, I'll have the exhaust and sways on by then, I ended up buying the front sway as well. Good to hear that. Set the front sway to the stiff setting and the rear one to soft. |
would you reccomend this to a person with a staggered wheel setup? 205/40 and 235/40 rear; yokohama s-drives
