Texas - Houston S2000 Owners Greater Houston Area S2000 Owners
Eibach Front sway bar review
Old 03-21-2013, 04:30 PM
thanasis11's Avatar
Default Eibach Front sway bar review
I went to Inline Racing yesterday and Matt installed my Eibach front sway bar among some other things. He requested a review so here it is:
Previous setup:
Tein coilovers 12kg/mm front, 10kg/mm rear
17x9 +63 wheels with 255/40/17 RS3's front and rear
rear toe control arms
apr gtc 200 wing
Alignment: 2deg camber front, 2.5 deg rear, max allowed caster, 0 toe front, almost 0 toe in rear
The car had very good rotation at slow speeds, was pretty balanced at medium speed turns and very very stable at high speed and would push quite a bit-the wing did its job
The problem was that when entering a corner a little too fast the tail would come right out.
To counter the high speed push i got a splitter but its not installed yet, and to counter the scary oversteer I got the eibach front sway bar. the swaybar was recommended by my instructor HPD, Thanks Andrea.
The bar is set on the stiff setting. My initial impressions after a day of driving and purposefully pushing the car to the limit upon every possible occation I must say that this is a great investment for similarly setup cars.
Here is what I was able to notice
Pros:
The car reacts much faster to steering inputs
Roll is significantly reduced. It feels almost flat
I can get on the throttle much earlier
Greater stability
Cons:
There is a slight weight gain at the front axle, probably 4-5lbs increase compared to stock ap1 bar
Rougher ride on uneven shitty houston streets
I will add my track impressions soon.
Thanks again to Matt for the install and Andrea for the recommendation
UPDATE:
My track experience with this bar:
So I atttended Drivers Edge at MSR Houston this weekend. The only change to my setup since last time I was here 2 months ago was the sway bar. The car felt ALOT less twitchy, much more controlable and my confidence was all the way up there. I was able to get on the throttle much sooner at diamonds edge and after the launch. The car also felt much more stable through the carousel.
Old 03-22-2013, 07:05 AM
Benn-O's Avatar
Thanks for the review buddy, hopefully this picks up more on this forum
Old 03-22-2013, 01:09 PM
thanasis11's Avatar
i always try to review everything. it really helps everybody if you think about how many hours you spend everytime you are considering a new mod.
Old 04-03-2013, 02:48 PM
SGTForti's Avatar
nice review.
Old 04-14-2013, 03:49 PM
Brndon's Avatar
thanks for these reviews!
Old 04-15-2013, 10:29 AM
thanasis11's Avatar
track experience added to the original post
Old 04-15-2013, 01:34 PM
ryuken's Avatar
Very nice job Thanasis. I had to let him pass me a couple of times hehe
Old 04-15-2013, 05:41 PM
jellis01's Avatar
Glad y'all made it out there, I was stuck on the wait list
I'll see y'all out at TWS! Thanasis, I'll have the exhaust and sways on by then, I ended up buying the front sway as well.
Old 04-16-2013, 12:25 PM
thanasis11's Avatar
Good to hear that. Set the front sway to the stiff setting and the rear one to soft.
Old 04-16-2013, 02:11 PM
Brndon's Avatar
would you reccomend this to a person with a staggered wheel setup? 205/40 and 235/40 rear; yokohama s-drives
Quick Reply: Eibach Front sway bar review
