Texas - Houston S2000 Owners Greater Houston Area S2000 Owners
Houstook Tech/mechanical thread
Old Oct 26, 2009 | 09:06 PM
  #131
Ali_houston's Avatar
Originally Posted by RacingEmotions,Oct 26 2009, 06:52 PM
i'm 90% sure its the rear driver side axle
Is there any way i can check for sure? and how ward would it be to replace that dang thing??
Old Oct 27, 2009 | 04:51 AM
  #132
belknap777's Avatar
Ali does it happen under acceleration or when you let off or both?
Old Oct 27, 2009 | 03:32 PM
  #133
Well dude its kinna not constant but i can say for sure when i am accelerating at a slow rate if it makes sense...and sometimes making a turn slowly...if i hit a bump on that side mostly it will happen too
Old Oct 31, 2009 | 11:17 AM
  #134
Benn-O's Avatar
well guys last night tried starting my car and all the lights would come on and i put the clutch and the starter would turn over but, not fire the engine. i also the green blinking key would not go away.
after doing a search on it. it seems to be an immobilizer system. where the key (microchip) won't talk to the ECU. does anybody know how to fix this. do i just unplug my alarm or do i need to get honda to make me some keys?
any help would be greatly appreciated. and any advice as well.
Old Nov 1, 2009 | 04:25 PM
  #135
Benn-O's Avatar
Old Nov 1, 2009 | 04:57 PM
  #136
VIC4UF's Avatar
Wish I knew so I could help.
Old Nov 1, 2009 | 05:28 PM
  #137
azunboy's Avatar
most probably a bad immobilizer receiver unit. 90% chance
and or bad key---but its a small chance like 10 percent
and of course..if you have an alarm system then check that cause most will hook up to the immobilizer unit and disable it
easiest way is to remove the key column cover, unscrew the receiver unit, swap with someone and attempt restart
the part isnt that expensive--like in the hundred something range last i check
  #138
azunboy's Avatar
i have two axles if youd like to swap and test
Old Nov 1, 2009 | 05:30 PM
  #139
azunboy's Avatar
Originally Posted by youngjae,Oct 25 2009, 06:08 AM
Does anyone want to meet up one day and help me clear corner my headlights? I'll treat lunch or something, thanks!
bring it to the tech meet, ill walk you through it
Old Nov 1, 2009 | 08:53 PM
  #140
That would be AWESOME man! i will PM u ma number now preciate it!
