Texas - North Texas S2000 Owners North Texas S2000 Owners Club
North Texas Club
Alignment settings
Old Sep 6, 2001 | 09:05 AM
AG Y2K S2K's Avatar
Default Alignment settings
Cdelena and I have discussed alignment settings but I wanted to see if anyone has additional suggestions. I just had my new S03's mounted and also had the car aligned. Now the car seems to dip and sway much more than before.
Alignment per the owners manual, Toe Front 0.0 rear - 0.24
Camber Fr - -0.30' rear -1.30'
Caster Front 6 deg
My new settings have a .21 rear toe and a caster at 5.1. I figure these specs in addition to the different tires are causing the change in handling.
Any thoughts before I have them do it again?
Old Sep 7, 2001 | 01:26 PM
Hairy Beanbag's Avatar
You might want to post this out in the Under the hood section. All the motor heads hanging around should be able to answer this. Plus you will have a much larger audience for your question.
Old Sep 8, 2001 | 07:03 AM
Molly W's Avatar
I don't have the answer, but I have the same problem. I got new rears Aug. 4. and had the alignment checked too. I even went so far as to have them put the alignment back the way it was.....it still drives weird. This is starting to sound like it may be the tire itself.
muha22752
Aug 24, 2012 02:10 PM
blasphemy101
Jul 12, 2011 09:05 AM
Squeezer
Mar 28, 2003 09:32 AM
