adjusting the tappets.
Old May 21, 2005 | 01:07 PM
s2uk's Avatar
Default adjusting the tappets.
my old Civic CRX used to have adjustable tappets and when they were adjusted it did make a difference, can the S's be adjusted?. couldnt find anything of use in any book or on the search thing.
car goes in next week for the CV boots to be re greased and whilst it was in thought i might have the tappets adjusted. it makes them run a little quieter thats all i know.
Old May 21, 2005 | 01:23 PM
S2000 0E's Avatar
i thought most modern engines have auto tappit adjusters, you surprise me when you say the ctr s were adjustable.... many a happy afternoon i spent adjusting and shimming my tappits on my 1976 mini van
Old May 21, 2005 | 01:31 PM
s2uk's Avatar
that was what i thought but when i asked honda they said yep we can adjust them. need the car as early as possible so its cold and they can do th ejob, this was for my crx going back 10 years, just thought things must have moved on so i asked. i am guessing they are auto adjusted but you never know if you dont ask.
Old May 21, 2005 | 01:34 PM
S2000 0E's Avatar
maybe even auto adjustables need adjusting now and again.... sounds irish to me
Rteyp's Avatar
They did mine at the 27k service last month.I think they must be done when engine is cold
Old May 21, 2005 | 01:37 PM
Pickers's Avatar
I think its an optional something they do at around 54k service - IIRC they only do it if sounds unduly noisy and its not an easy thing to do properly.
I remember "Turtle" (aka Brian posting on this some time ago - if you do a search under his name, it should come up
Old May 21, 2005 | 02:18 PM
MOLLYSLIP's Avatar
Mine was in last week to have the tappets adjusted as i noticed
the engine was a little noisy, i thought it was the timing chain as
i was under the impression the tappets were self adjusting !.
Johnson Honda in Slough were correct and it now feels like
a new car.
My first experience with them.
Mollyslip.
Old May 21, 2005 | 02:42 PM
AquilaEagle's Avatar
Administrator
IIRC the little tapping noises can also be valve clearances, which I think are checked on the major services
Old May 21, 2005 | 03:28 PM
urchin's Avatar
i had valve clearances checked at 36 month service...
they said they can usually tell a car has been ragged if the valve clearances need substantial adjustment and said they surprised how little mine needed...
Old May 22, 2005 | 12:37 AM
biker1's Avatar
Just so you know Mr Eagle, the tapping noise you hear are the "rockers/tappets" hitting down on the top of the valves. So valve clearance - tappet adjustment is the same thing, just said differently.
They are adjustable and when done correctly/precisely make the engine sound very sweet and quite ( this does take time) unfortunately most garages including Honda ones don
