AEM EMS Base Map
In preparation for driving up to Jockland for the Arran meet .....
I am looking for an AEM EMS map that I could use if I had problems with my SC and had to remove the belt. Can anyone point me in the direction of a EMS map that I could use on a standard(ish) car but with 750cc injectors?
My other option would be to use the OEM ECU but I believe that I would also have to swap the injectors to do this.
You would haveto swap the stock injectors back in and tbh the problem would be getting a stable map for a stock engine using 750cc injectors as they are massive.
Why would you hav problems with your sc anyway?
I had the same issue when I took off the SC.
I didn't have stock injectors to swap back in either.
I even went so far as to use a VAFC with all the injector duty turned down to max - 50% (360cc -> 750cc), and that didn't work.
I could have used the stock SC map, but it'd only use the -ive boost part of a larger map.
I ended up speaking to MASE who sorted me out a map.
I then got it tuned a few months later as an NA & 750cc. And then got that map tweaked as it'd stall occasionally when cold.
Originally Posted by MB,Jul 6 2009, 10:05 AM
So you have a map you could supply to Steven then, Ben?
Sounds like you have an NA 750 map...
Even if it's roughly right it will be useful as a limp home option.
Even if it's roughly right it will be useful as a limp home option.And would need to speak to MASE to make sure it's okay to pass on. As I know he'd only want it to go to a customer of his
Steven, drop me a PM with your email .. and I'll have a look.
Originally Posted by kitkat,Jul 6 2009, 10:13 AM
car should be fine to drive on the sc map without belt if you stay under vtec xover - eSem you changed your vtec point to 5k yet or is it still super low ?
This would mean that, without the belt, I would not be able to engage VTEC and I should be OK to drive the car up to ~ 7000rpm
