AEM EMS wire harness
Old Apr 26, 2009 | 05:56 AM
phils2k's Avatar
Default AEM EMS wire harness
I am off to spa on sat and i have an issue with the AEM, one of the injector drivers has gone down, and not fuelling no 3
I am wondering if anyone has a spare wire harness for the ems or any of the conector pins for the wires to go into the connector blocks on the rear of the aem
Cheers Phil
Old Apr 26, 2009 | 07:41 AM
eSeM's Avatar
Phil, the AEM uses the OEM ECU harness.
Old Apr 26, 2009 | 10:05 AM
mikey k's Avatar
Old Apr 26, 2009 | 10:30 AM
phils2k's Avatar
sorry i had a number and one things on my mind and then realised what i wrote
anyway hopefully getting there, maybe able to use a spare port until i get back from spa and then send the unit back to AEM for a replacement like Dave did (kitkat)
Old Apr 26, 2009 | 11:33 AM
kitkat's Avatar
phil phone aem - there is a spare injector driver on the pin out aem will tell you how to wire it. BTW if you want to borrow an aem to go to spa then drop me a pm - i often dont need to use my car for weeks at a time so its no real issue + im on the way to dover
and ive got a spare block too thats used for the extra injector driver - but i get the feeling you will need to cut / hack the loom to get this to work.
PS - when you send the aem back make sure that your write temporay export on the pro forma and make sure that you also write warranty repair. (even if it isnt) as your original paperwork will go someway to deciding how much HMCR want to tango.
Old Apr 26, 2009 | 11:43 AM
phils2k's Avatar
dave cheers, i have found the wire and the spare ports for the injector, i am just waiting on mase to tell me what i need to change on the map if any, took me all day to figure out what wires are what lol
but i might take you up on the spa/aem if all else fails, pleny of beer coming your way if so
Old Apr 26, 2009 | 11:53 AM
kitkat's Avatar
no fill your boot up in france with vin rouge if you borrow it
Yaseen74
Feb 9, 2018 07:09 AM
S2000ABQ
Oct 20, 2015 03:00 PM
starrman
Apr 25, 2012 03:30 PM
ekoms31
May 23, 2010 07:00 PM
ShMooveS2k
Jul 10, 2007 09:15 AM
