air filter
Old May 7, 2008 | 11:55 PM
nashby's Avatar
Default air filter
does anyone have an idea on which air filter to replace stock item with, is paper or foam better, surely it's best to have a bell mouth, what make? i just want one thats washable and sounds good and works the best
Old May 8, 2008 | 12:23 AM
MB's Avatar
MB
Member
Nashby, try having a search my friend.
This is possibly the 10000000 time this topic has come up
You can either epalce the element with a K&N or similar, and add a snorkle, or go for a new airbox.
PS - that's some list of vehicles!
Old May 8, 2008 | 12:28 AM
nashby's Avatar
Thats not all of them but did you notice the 4x4 panda, i did a search and it seems to just come up with k&n typhoon or gen II
Old May 8, 2008 | 01:22 AM
tomkbucks's Avatar
yup im about to do this , i want to keep the stock airbox but keep the lid off
i think the standard K+N cone filter type looks ok and is around
Old May 8, 2008 | 01:33 AM
nashby's Avatar
i'm not convinced on the k&n cone filter replacement being of benefit other than it's washable and leaving airbox lid off will lose you a small amount of power
Old May 8, 2008 | 01:36 AM
MB's Avatar
MB
Member
K&N would be my choice if you are replacing the OEM one.
4x4 panda is the daddy
Think my dad had a Y plate old one!
Old May 8, 2008 | 01:41 AM
tomkbucks's Avatar
thats what i thought as its washable means i dont need to buy another - normal honda ones are what
Old May 8, 2008 | 01:50 AM
nashby's Avatar
true, you can't stop a panda, used one regularly as a comuter to uni, 3 blokes poor thing
Old May 8, 2008 | 01:57 AM
nashby's Avatar
just meant that even with the k&n if you have air box lid off you will lose a bit of power, true?
Old May 8, 2008 | 02:23 AM
MB's Avatar
MB
Member
In theory yes.
I think on the move the heat soak is less of an issue.
The only reason for removing it is nice noise, and you sacrafice a bit of throttle response power.
The K&N will flow a bit more air.
But if you want the best of both you have to go for a different design airbox.
