Air Pump CEL
Situation:
Cold engine on Sunday, CEL comes on when I start it. The car drives fine, VTEC works etc.
I clear the code (yes I'm a naughty boy) by disconnecting the battery then restart the car...the CEL does not come on.
I start the car this morning, and after a few seconds, what seemed like a bit of a misfire (it could have just been my poor clutch control), the CEL comes on again. The car still drives fine...
I read the code this evening via the JDM blink method, and it shows 6 long flashes of the CEL, which according the WWW means 'Air Pump'. This is obviously not very helpful, and rather ambiguous. If preliminary investigations draw a blank (fuses/relay etc), is there anyone in the area that could lend me a OBD reader? It would need to be OBD1 compatible as my S is a JDM
I will be in S.Wales for 9 days as of Friday if there is anyone up there that can help
AJ has very kindly given me some advice
, but if anyone else is able to say where the fuses are for it (my fuse box layout is in fecking Japanese) and confirm what he has said, it would be much appreciated
Gary is a top guy, and is sending me his Scangauge to borrow. BIG
I managed to locate the 60A fuse (in the small fusebox next to the battery) and the 15A ASG fuse, which is referenced in the service manual and applicable to the airpump...both are fine.
The next step will be to whip off the NSF wheel and arch liner to see if anything is obviously apparent...I may even take the relay (possibly solenoid too) apart and see if they need cleaning up.
Hopefully the code from Gary's reader will be able to narrow down the fault if nothing comes from having a shifty around.
FWIW, JDM owners can use the following method to get 'blink codes', using the CEL light on the dash:
http://www.modifry.com/freebies/old/dtc/index.htm
The connector resides just under the dash, where a passenger's right knee would sit.
Sure I read somewhere that someone else had an Air Pump code and it was actually the battery leads that needed tightening as there wasn't enough juice going to the components which meant a CEL - might be a quick and painfree step before pulling it all apart
I shall go and take a peek, although I replaced the -ve connection the other night because the previous one was loose, and all seemed well.
