Air pump delete kit
Has anyone made their own delete kit? I see you can buy them from the states for $100 odd. Presumably they must just consist of a few bits to fake the correct sensor feedback to the ECU at the point at which voltage is applied to the pump, and for a period thereafter?
Cheers
Gary
Anymore detail on the contents of the kit.
My previous understanding was that tricking the ECU was quite difficult, and the delete kit was just the blank flange to cover the manifold position. Meant that you needed an aftermarket ECU in order to not have a CEL.
Maybe things have moved on, for $100 you'd hope so!
From what I can see, it should a relatively simple job for non-US cars, but nigh on impossible for the US spec wiring/ECU.
https://www.s2ki.com/forums/index.ph...=711974&st=500
At the moment I've blanked mine off but it's the CEL I want to address, so I think I'll take a closer look.
Wayners - did you solve the CEL problem too?
There was a kit sold in the US but the vendor ended up refunding the buyers as the CEL issue couldn't be solved.
Originally Posted by razzele,Dec 23 2010, 05:45 AM
He solved the CEL with a stand alone ecu!
I cant give you exact details as to what was done as 50% of it my dad did; we made the blanking plate out of 3mm alluminium.
Originally Posted by Wayners,Dec 23 2010, 02:21 PM
Interestingly enough, ive not got a CEL and im not running the standalone yet!
I thought u were mase'd & AEM'd by now !
