Alarm Sensivity Adjustment
Old Jan 22, 2007 | 03:43 AM
CiderBoy's Avatar
Default Alarm Sensivity Adjustment
Since replacing my battery my alarm keeps going off when I have the top down.
I've been told that the alarm sensivity will need to be reset.
Having completed a search I have found a few references, but no instruction.
Any ideas?
Thanks in advance
Nick
Old Jan 22, 2007 | 04:30 AM
Lloyd Six's Avatar
No matter how weak it is set they will still go off with top down.
Press the lock button for a second time when roof is in down position to deactivate the interior sensors.
Old Jan 22, 2007 | 05:16 AM
H!cks's Avatar
Do you get any notification that the internal sensors have been switched off (i.e. lights flash)?
Old Jan 22, 2007 | 05:27 AM
andyds2k's Avatar
Yes, the indicators should flash a couple more times after you press the lock button again.....well it does on my MY00!!
Old Jan 22, 2007 | 05:43 AM
H!cks's Avatar
Cool, I'll give it a crack because I don't usually set the alarm when the roof is down, just the immobiliser.
Old Jan 22, 2007 | 08:01 AM
CiderBoy's Avatar
It never used to before I disconnected the battery!
Old Jan 22, 2007 | 08:16 AM
Lloyd Six's Avatar
Thats because someone had programmed the alarm to personal taste and now it has gone back to the factory settings.
Need to look in my alarm book under programming but TBH I would keep it how it is now and do what I said with the second press. It does flash the indicators again on the second press to let you know that interior has been deactivated.
Old Jan 22, 2007 | 10:59 AM
CiderBoy's Avatar
Lloyd you spacker!
You've gone completely full circle on me.
I know it's gone back to factory settings and needs to be adjusted back to how it was before.
But I don't know how to do this! Hence the bloody post.
Does anyone know?
I liked it the way it was before.
Old Jan 22, 2007 | 12:00 PM
Amuse Boy's Avatar
http://www.bassoctopus.com/s2kuk/S2000alarm.pdf
There is a way of adjusting the sensitivity but I can't find the instructions for the OEM system. Still searching...
Old Jan 22, 2007 | 01:24 PM
CiderBoy's Avatar
Amuse Boy,
Thanks for your help again.
'll have a look through that in the morning.
Nick
