Alignment....help?
Old May 10, 2012 | 12:16 PM
AlexGJ248's Avatar
Default Alignment....help?
Hello everyone, I am pretty sure my alignment needs sorting as my steering wheel is slightly off whilst I am traveling in a straight line! I have the ability to do this myself, but I dont know the correct camber/toe it should have from the factory. Plus I've recently had AD08's fitted on the front and I dont fancy them wearing away quicker than they should just because of the alignment! Thanks
Old May 10, 2012 | 01:15 PM
WinFreak's Avatar
Standard settings are in the FAQ I think
camber front 1.0
caster front 6.5
toe front 0 0
camber rear 2.0
toe rear 0.20 0.20 overall 0.40
Some might put more toe on the rear but as yours is a facelift it'll bumpsteer less anyway and toe eats your tyres.
If you want a more track based or faster road setup or whatever people call it, you could up the camber a bit, fit a bumpsteer kit and reduce the rear toe
I'm running 1.5 on the front, 2.5 on the rear and 0.20 overal toe and I like it
Old May 10, 2012 | 01:25 PM
AlexGJ248's Avatar
Cheers WinFreak, I'll give it a go tomorrow at work
Old May 10, 2012 | 02:54 PM
Si2k's Avatar
Try zero front toe with those tyres. 0.1 on each rear. Should be pointy and help tyre life
Si2k's Avatar
Si2k's Avatar
Old May 11, 2012 | 06:25 AM
danwebster's Avatar
What units are you all working in, when you say 0.20 and 0.1 are you talking minutes or degrees?
Old May 11, 2012 | 06:28 AM
Suits's Avatar
camber front 1.0
caster front 6.5
toe front 0 0
camber rear 2.0
They're too aggressive for OEM aren't they ??
That's pretty much what I'm running now after a fast road set up .
Old May 11, 2012 | 06:29 AM
Suits's Avatar
Degrees mate, in the post above with the figures anyway.
Old May 11, 2012 | 06:36 AM
danwebster's Avatar
So are you saying 0.2 of a degree or 20 minutes, because the two are not the same yet 20 minutes is expressed as .20
