Alignment with roof down?
Old Aug 29, 2016 | 10:54 AM
DaveUK's Avatar
Default Alignment with roof down?
Hey guys.
I have an alignment tomorrow morning. I've got a load of weight plates to put on the driver's seat. I'm just wondering if I should put the roof down as well, since I have the roof down if it's not wet, and if it is, then I don't drive fast.
Best motoring international tested the car with roof down vs up, and they found it to be faster with the roof down. That would have been with OEM settings though. That might also have been prefacelift I can't remember. Would Honda have taken the roof weight into account, and already tuned the settings to be ideal with roof down, whilst set with roof up? The better time might have been more to do with balance idk.
Would do you reckon? Cheers!
Old Aug 29, 2016 | 11:00 AM
Fatbloke's Avatar
What event are you entering and will the fraction of a millisecond you save make the difference between glory and humiliation?
Old Aug 29, 2016 | 11:19 AM
DaveUK's Avatar
So it will make a difference you reckon? I just don't want the settings to be messed up the moment I drive off.
GreenmanS2000's Avatar
About as much difference had having a big dump before you sit in the car....
Old Aug 29, 2016 | 11:35 AM
Fatbloke's Avatar
What volume of fuel will you have in the tank (in ml please)?
Don't forget that the movement of the oil as it drains back to the sump and the coolant condensing in the header tank will have an effect, so make sure you don't turn the engine off until the very last moment!
HTH
Old Aug 29, 2016 | 11:40 AM
Have you got nitrogen in the tyres?
What weight are your valve caps?
You'll need to adjust for the drag on the aero style wiper blades if you have those fitted
Old Aug 29, 2016 | 11:41 AM
DaveUK's Avatar
The fuel will be a little over half tank. The oil should be OK, because it doesn't move back and forth much. I didn't think about the overflow tank. I'll have to weight it hot tonight, and make sure it's the same while they do the adjustment.
Thanks for the help.
Old Aug 29, 2016 | 11:42 AM
DaveUK's Avatar
Standard wiper blades. All that matters is the weight that changes position.
Old Aug 29, 2016 | 11:52 AM
Fatbloke's Avatar
Have you allowed for the more rapid tread wear of the tyres on the driven wheels? Make sure you book in for weekly adjustments?
Old Aug 29, 2016 | 12:00 PM
DaveUK's Avatar
Mmmm...that's going to increase caster slightly. I can probably live with that, especially since I have no choice. Weekly adjustments would be crazy money.
