Is allignment checked at service?
Old Jan 17, 2008 | 10:42 AM
Road_runner's Avatar
Default Is allignment checked at service?
Hi all,
I'm going to look at an S this weekend and one concern I have after reading many threads on here is that is that the alignment will be out and the the bolts will be seized, hence a very costly repair.
Could somebody tell me if Honda check the alignment at services? The particular car I am going to look at has just had its 54k service.
Also any other points and things to check for on the car would be much appreciated (I have already read the FAQ and buyers guide).
The car I am going to see is this one:
http://www.pistonheads.com/sales/338130.htm
Old Jan 17, 2008 | 10:51 AM
motogp1's Avatar
not unless you ask and pay for it .
email the seller to see if he's had it done if he has he will have a print out of geo settings.
it is not the end of the world if they are seized, i had 5 i think, got cg to strip out bushes grease/replace ones that needed it, stillcheaper that what honda would charge for one corner.
Old Jan 17, 2008 | 09:50 PM
Thanks Motogp1,
I don't think it has had a recent alignment check then as the seller was wondering if they checked this at service.
Are Honda dealers able to check this quite easiliy or is specialist equipment required?
Old Jan 18, 2008 | 02:41 AM
aldfort's Avatar
Originally Posted by Road_runner,Jan 18 2008, 06:50 AM
Thanks Motogp1,
It's not part of normal servicing and is quite specialised.
For a car like the S2000 it's best to go to a spcialist who has decent quality alignment kit and who knows how to use it.
It is not a
Old Jan 18, 2008 | 08:40 AM
veehexx's Avatar
a decent garage would see the tyre wear and should inform the customer about their geo being incorrect.
in reality, alot of garages just want to see the bill at the end and get the next car in.
if the geometry is out by a long way (had a bump /not been setup after bush replacement), then tyre wear will be evident.
on road test check for pulling to one side, visually look at the tyres; are they worn funny.
rear tyres should wear dead even, since they dont do any active steering. at the end of the tyre-life, it might be acceptible to see one edge of the tyre worn more than the rest (inside edge). aslong as your looking at the last 2mm or so, thats fine. if the edge is completely worn away, with only 1/2 tyre life then it's safe to presume something isnt quite right.
saying that though, under/over inflation can cause weird tyre wear, a knackered shock or track-rod end etc, it's not just geo that causes bad tyre wear and possibly bad handling.
going price for geo check is
Edmac2493
Aug 21, 2013 06:08 AM
shirty
Oct 11, 2010 07:02 AM
Mrblu
Dec 3, 2008 01:34 PM
douglasr
Mar 16, 2004 06:24 AM
SilverS2KAZ
Sep 16, 2002 12:53 AM
