Alternative tyre sizes
Old Jul 15, 2013 | 08:46 AM
MB's Avatar
MB
Member
They are 260mm wide in 255.
http://www.federaltire.com/download/spec595RS-R_Eu.pdf
Toyo R1R is 262mm
Your Falkens in 245 are 250mm
Old Jul 15, 2013 | 09:00 AM
mdb_75's Avatar
Here are some pics of my 225 and 255's fitted to OEM wheels.
Attached Thumbnails Alternative tyre sizes-side.jpg   Alternative tyre sizes-rear.jpg   Alternative tyre sizes-side-angle.jpg
Old Jul 15, 2013 | 11:10 AM
sound_wave's Avatar
Toyo R1R is 262mm
Ok so it needs to be the 255. Out of interest, how wide is the Bridgestone? I always thought they were wider than the Falken.
Old Jul 15, 2013 | 02:10 PM
surfer_crx's Avatar
I have the Federals on my track CRX and they are great. However I definitely would not use them on the road as they need heat in them to get going, the S2000 may be able to generate that but the CRX certainly can't, at least on the road anyway.
Old Jul 16, 2013 | 09:56 AM
sound_wave's Avatar
Anyone know if the S will put heat through the tyre to warm them up? Have I bought a set of lemons?
Old Jul 16, 2013 | 10:03 AM
MB's Avatar
MB
Member
Depends on compound.
The S is heaver and works all 4 wheels more than a CRX will though.
Old Aug 15, 2013 | 02:56 AM
dan_bourne's Avatar
seeing as we cant get the ado8, and the 595 rsr's are not good for the winter/cold/water etc, will that toyo r1r be the tyre to go for?
im off to spa in october and want a decent tyre for that too...
Old Aug 15, 2013 | 03:28 AM
WinFreak's Avatar
Bit of luck the ad08r will be here by then
Old Aug 15, 2013 | 04:50 AM
sound_wave's Avatar
Who said the RSR isn't good in the cold or wet? I've been running them in the wet weather for the past few weeks and they've been fine? I've not pushed on in the wet with them on, admittedly, but then who does with normal tyres?
Old Aug 15, 2013 | 07:06 AM
dan_bourne's Avatar
There's a post on this very thread that said they arnt good in the wet/cold, and not able to get heat in them (albeit on a crx) for just road driving, also repeated in other threads on other clubs,
I like to drive my car in any conditions, not pushing it, but I don't want them to be lively when I'm not ready for it just cruising about. They don't clear water particularly well.
the r1r's are said to be better when colder and clear water better. Can also get the correct sizes. Horses for courses, I dont think i would be happy running them through the winter that's all, if you are that's cool : )
Just after some more advice
