Amazing what difference
Old Mar 11, 2009 | 02:55 AM
shepp's Avatar
Default Amazing what difference
I purchased a lambda sensor scepticaly from Ebay
Ebay sensor
On Saturday i decided to replace it using J8mie's guide
Thanks J8mie
Firstly jacked up the front of the car, looseded the existing sensor, then tried to undo the connector to the loom, then knoticed a bracket holding the cable to the gear box.
Undid the bolt which allowed the sensor to dangle approx 6 inch below the car, so it made it possible to cut off the old sensor, leaving enough to reconnect if the ebay sensor didnt work.
Attached the crimps to the new sensor, screwed it in, then crinp to the existing wiring.
Takes approx 20 minutes
The difference is amazing, after 200mile the guage showed it still had half a tank, I thought i had buggered the fuel gage, as asually it would be empty, but it still had a a third of a tank, The car has no hesitency in traffic, no more dancing in traffic when accelerating from approx 5mph, then having to slip the clutch. I can now confortable tootle in 6 gear at around 30 mph and gradually accelerate.
I know the s is not about tootling but when you are in traffice you dont half feel a pratt when your car decided to break dance.
Old Mar 11, 2009 | 03:02 AM
s2konroids's Avatar
Why did you replace it? it take it is was damaged or something?
Old Mar 11, 2009 | 03:10 AM
tomkbucks's Avatar
i take it it only needs to be replaced if you rthrowing a CEL or something ? my car is on 80k miles and does 240miles to a tank , if i can make it go better for
Old Mar 11, 2009 | 03:13 AM
s2konroids's Avatar
[QUOTE=tomkbucks,Mar 11 2009, 11:10 AM] i take it it only needs to be replaced if you rthrowing a CEL or something ? my car is on 80k miles and does 240miles to a tank , if i can make it go better for
Old Mar 11, 2009 | 03:14 AM
shepp's Avatar
Replaced it because the s was suffering High mpg, hesitation, Kangaroo fever, revs dropping off, very little torque on low revs (i know they have little torque anyway but i was unable to let the car roll in first gear without touching the accelerator as it would dance, now it will hapily roll in second)
I replaced it firstly, its cheaper than a MAP sensor, and both have similar symptoms, as they both contribute to the fuelling/air controll.
Definatly worth a try if you have the above problems,
It will only throw a CEL if it has failed, not if it is failing and giving incorrect readings to the ECU,
My S used to always do approx 240 to a tank, and it does again now.
fuel consumption is an issue as i am driving to the Monaco Grand Prix in May so every extra mile is welcome.
Old Mar 11, 2009 | 03:15 AM
GrittyShaker's Avatar
Good result.
Mine suffers from really terrible kangarooing in traffic. I haven't tried much to rectify it as yet, but for the price it seems it might be one of the first things to try.
Old Mar 11, 2009 | 03:42 AM
chrispayze's Avatar
Hmmm interesting, I've noticed mine a little worse than normal over the winter (not usually a problem until summer months) so I might give it a go for the sake of
Old Mar 11, 2009 | 03:51 AM
shepp's Avatar
definatly worth a try chrispayze, the reason i changed mine was the kangarooing in winter, abviously a fuel/air mixture problem especially when i put in new plugs just befor winter, Did help because the old ones were very worn, but the new sensor has cured it
Old Mar 11, 2009 | 03:59 AM
McHeizer's Avatar
How many miles do you have on your car now?
What strikes me is that the sensor obviously did have a problem...
However it didn't throw a CEL, did it?
Old Mar 11, 2009 | 05:15 AM
shepp's Avatar
Ive only got 40K on the car, but the sensor takes alot of punishment at the end of the manifold, I know a few auto electricians and they recon they go all the time on cars and dont throw a cell, usually on older cars they fail the emissions on the MOT due to incorrect mixture but the s is fairly clean.
