Annoying squeak!
Old Mar 2, 2005 | 01:53 AM
Crusader Rabbit's Avatar
Thanks all!.
Sounds like size could be a factor here?? (no jokes please!!!!!!!!!).
I just wonder if trying to use the longest blades possible (which I think are 20" and 16" before you start hitting trim etc) you get this. Never used to get it with the standard size Honda blades.
Old Mar 2, 2005 | 01:56 AM
Shiskine's Avatar
I've ordered some new blades through s2k here on the board, and he's supplying 20" (passenger side) and 18" (driver's side), both with spoilers.
I was concerned with the extra length on the driver's side, but when I look more closely at my current setup, there's at least an inch top and bottom to allow the bigger wiper.
Old Mar 2, 2005 | 01:59 AM
Originally Posted by cerberus264,Mar 2 2005, 09:54 AM
I never got round to cleaning the screen. I just turned my music up to cover it.
I know its a bit like chinese water torture and drives you mad.
This squeak is very loud!!!.......even when stereo racked up!. Worse than water torture I can tell ya!.
Old Mar 2, 2005 | 02:12 AM
GSi's Avatar
GSi
you sure it's the blades? and not the mechanism?
Old Mar 2, 2005 | 02:18 AM
cerberus264's Avatar
thinking about what was said earlier here, I may have had oversized wipers on one side too ...and i think that was the side that was squeaking. I sold the car and I never got round to resolving the issue.
Oversized wipers of other makes never gave me a problem but maybe there's something in it with the Bosch blades.
Old Mar 2, 2005 | 02:19 AM
Shipley's Avatar
Clean your windscreen with vinegar or something basic like that. Get everything off it.
Make sure the new blades have been similarly cleaned
Ensure its not te wiper arm iteslf squeaking
RainX is good for making the rain streak thus negating the need for wipers, its not for cleaning windscreens
Old Mar 2, 2005 | 02:29 AM
GSi's Avatar
GSi
Nice Summary
Old Mar 2, 2005 | 03:32 AM
Pretty sure it's the blade. I put my fingers on the windscreen where the passenger side blade reaches the top of its swing and you can feel the vibration in the glass where there is obviously some increased friction. However, could be the arm applying too much pressure (eg. if bent)???.
Old Mar 2, 2005 | 03:33 AM
May try giving screen and blades a clean with glass cleaner (haven't done that for a while because of weather.........just usual car shampoo type clean). If that fails, may resport to Honda blades or shorter Bosch ones unless any other solutions come up!.
Old Mar 2, 2005 | 04:36 AM
GSi's Avatar
GSi
Is the mechanism free moving at the base of the wiper? the ones on the volvo had loads of crud in them which was stopping it pressing against the screen firmly. Just needed cleaning out and a bit of WD40.
The spring should hold it against the window with the correct pressure, so if it's free moving I guess thats ok. Tried it without the spoiler?
