Another BZ for DMS
Old Aug 25, 2011 | 09:11 AM
loftust's Avatar
Default Another BZ for DMS
I took my S to Dixon (DMS) last week to get Hardrace Toe Arms fitted, and the Geo carried out.
After some discussion, we came up with a setup (perhaps a compromise of our two opinions) which at first appeared to be very good...the car had shed loads of grip, and the bump steer had disappeared. A couple of hundred miles later, I decided I wasn't happy with the setup, the steering felt numb and the car dived alot under braking, so I contacted Dixon to arrange remedial action.
He very kindly invited me back to remedy the setup without any other customers present, so the whole day could be devoted to my S.
I took the car back to him today, and his setup is spot on...he re-jigged the ride heights, and adjusted the rebound/bump on the dampers (which for some reason were all over the place ) to what he knew would offer comfort and performance.
The car is excellent with a MUCH improved ride. There's no understeer, but a tiny hint of oversteer which suits me (it was wet when we tested it). The grip is excellent...even in the wet, and the whole car feels exceptionally balanced.
...after all of this, he did not charge me for the work he did today...thanks Dixon
Highly recommended.
EDIT: Here are my settings:
Front Camber: 1°20'
Front Toe: 0°
Caster: 6°45'
Rear Camber: 2°15'
Rear Toe: 0°10'
Old Aug 25, 2011 | 09:16 AM
Fontal's Avatar
Just wish I lived closer
Old Aug 25, 2011 | 09:37 AM
Si2k's Avatar
Very similar to mine, im on 6'20' of castor though
Old Aug 25, 2011 | 11:41 AM
Dan Hale's Avatar
Is Jackspeak allowed here?
Glad the car is sorted & you're happy, shippers.
Old Aug 25, 2011 | 11:54 AM
s2konroids's Avatar
Sounds good matt, how is the prospective tyre wear? or would your previous settings be more suited to less tyre wear?
Old Aug 25, 2011 | 11:59 AM
loftust's Avatar
Tyre wear is good thus far (Goodyear Asymmetrics), and the distinct reduction in toe (30' to 10') will only aid this, despite the increase in camber.
My previous damper settings were more suited to semi slicks, giving the tyres a harder life than they needed to incur.
If I were overly concerned about wear, I would have opted for 1°45' camber.
loftust's Avatar
shippers
Old Aug 25, 2011 | 03:03 PM
Ultra_Nexus's Avatar
Tiny hint of oversteer?
That is definitely and understeer setup!! (assuming you are running the 17" stagger setup)
The lack of rear toe will make you think it's oversteer biased, but that'll just make it easier to power oversteer.
HTH
Old Aug 26, 2011 | 12:13 AM
loftust's Avatar
That's what I meant, and just what I want
Old Aug 26, 2011 | 03:35 AM
Nick Graves's Avatar
I tend to prefer that too; predictable-onset oversteer. Given the firmer grip form the wider front rims, that tends to be gentle-oversteer everywhere.
Mind you; I can still fine-tune the rear toe using this foot pedal...
