To anti bumpsteer or not
Me too, I'm guessing you'll need to sort some longer bolts? Seems like 12mm is a common thickness for these spacers...
Anybody know the bolt specs of the top of their head?
If it really bothered you, you could get the plates powdercoated for peanuts any colour you want, which I might get done myself...
I ended up getting my rack spacers for £25, so not too bothered and I fitted them because the correct thing to do is have completely horizontal track rods at neutral suspension.
You probably don't need them, but you might as well do it properly.
As for the rear, i'll perform some movement tests when I fit new suspension...again!
Originally Posted by TangoVTEC,Feb 15 2011, 06:08 PM
That did occur to me!
Anyone got a picture of em fitted?
I have front and rear installed.
Originally Posted by Dembo,Feb 15 2011, 08:56 PM
I thought they made a world of difference.
And it's the rear you can't get into spec (or at least don't have the full range of adjustment) without the anti bumpsteer bits.
The angle of the front steering arms was VERY different after a 2" drop.
So the way the steering angles, in particular toe and ackerman, are changed in a hard corner is not good.
Chris Franklin at Centre Gravity did have a load made to a pattern.
Maybe he still has some to clear out?
They are a pig to fit.
i am looking to install a rear bsk aka rear toe arms on my 2001 s2000 but im not sure which kit clears the stock ap1 16 inch wheel.. can anyone point me in the right direction please ! thanks !
