Audio Question? - not more?
Old Oct 18, 2005 | 08:07 AM
Yinmeout's Avatar
Post Audio Question? - not more?
Whadaya think about these as rear speakers?
http://www.caraudiodirect.co.uk/product_in...b584b80039a1ca6
I think they should fit in without metal trimming and should provide a nice mid range infill and some extra base without a subwoofer. I have Infinity Kappa's in the doors and can make my ears hurt listening to some of my favorite trance tracks! woo hoo. Anyhow I want more mid base base with less volume but can't, just can't consider a sub in the boot. After spending about 20 hours reading simply hundreds and hundreds of posts on rear speakers wiring options sound stages drowning etc etc etc - I see that without seriously compromising space there is nowhere else to stick a sub.
The HU is Alpine 9853R (50W per channel) which has speaker delay so I can get the stage wherever I want it... I read that raiding a floppy disk drive power lead will provide the necessary plugs for the stock loom connector and onto those I can piggy back my rear speaker cables.
Not interested in Spods at all.
I'll probably get some Lucid rear panels just so as I can keep the originals....
Anyone any thoughts on that lot?
Old Oct 18, 2005 | 01:58 PM
mikey k's Avatar
Nice speakers - bloody shame (waste of money?) to cram them in behind the seat.
I did this with my Boston Acoustics
Old Oct 18, 2005 | 03:43 PM
Ruckus's Avatar
/que Barry Scott type voice over
Need a sub ? ....
Got no space ? ....
What can you do ? .....
You need Phase Linear ALIANTE range ! ......
Flat subs that DONT need a enclosure to boot
Old Oct 18, 2005 | 11:24 PM
mikey k's Avatar
maybe I'll try one of those in the passenger foot well
What do you think Ruckus? Anywhere good to get them from?
Old Oct 19, 2005 | 04:16 AM
Ruckus's Avatar
Well a quite neat place to install it would be inside the sparewheel.
You would need to make a flater screw mounting thing (to hold the wheel in place.
And then just a round MDF panel to go over/inside the wheel with the sub mount on it.
Would be a good idea to make the panel just a little smaller than the wheel so the tyre holds it up thus giveing it a soft rattle free mounting.
There woul have to be some way of holding the panel down also....
Not sure on it all but i think with all the bits in front of you anyone with half a brain could work it out
And yeah mikey a small panel at the end of the foot well could work well also.
Yinmeout re: your PM yes you would need an amp to power this, and TBH only pretty low spec subs come 'powered'... avoid them
Old Oct 19, 2005 | 04:20 AM
mikey k's Avatar
and I agree on the subs with integrated amps
Old Oct 19, 2005 | 05:41 AM
Paper Lawyer's Avatar
I wonder if the sub would fit UNDER the passenger seat?
Old Oct 19, 2005 | 05:55 AM
lovegroova's Avatar
Just a thought, is a sub really necessary here? Would not the addition of a power amplifier to drive the existing Kappas do the trick? The addition of the amp to my 9833R made a big difference to sound quality, both at high and low levels.
Of course, not listening to crappy Trance music would help the most
Old Oct 19, 2005 | 06:45 AM
mikey k's Avatar
amp first then a sub driven off an amp if you want it.
Old Oct 19, 2005 | 08:00 AM
Yinmeout's Avatar
Alrighty - well looks like some authopedic shoes are in order.
1. Change the crap music taste that'll sort out half the issues!!
2. Change the car for one that I can fit some sound into!!
Seriously guys - appreciate the feedback...
So you reckon I should amp the kappas as a first stage and then look at adding a Sub if I am not happy with the results?
For the terminally ignorant here - why is power amping the kappas (they are 5 1/2" btw) so much better than driving them from the stock HU?
I'll definately what to put a smallish amp under the passenger seat next to the iPod control unit K wahtever it is from Alpine - it's preatty small - any amp recommendations?
Crikey I'll be a flippin audiophile in no time at this rate!
