Auto window switch
Old Jun 22, 2005 | 02:24 AM
ade73's Avatar
Default Auto window switch
After fitting new speakers and putting everything back together i've found the Auto window switch dosent work, the switch works just like the passenger one where you have to keep it pressed down. Had a look at the connectors and everything looks OK.
So any ideas?
Old Jun 22, 2005 | 02:29 AM
Sundance's Avatar
mikeyk in another post said the auto window switch on his stops working for 20 mins after he disconnects (and reconnects) the battery.... Not sure if this is relevant to your problem or not
Ash
Old Jun 22, 2005 | 02:36 AM
Amuse Boy's Avatar
Did you disconnect the battery? If yes, you need to program the window to use the auto function.
Put the window all the way up and then click the auto up and hold for a few seconds - should sort it.
ade73's Avatar
Unfortunately not, left overnight and its still not working.
Bizarre, i did the hold it thing yesterday and it still didn't work, thought what the hell i'll go try again and still nothing, on the 3rd attempt held and nothing, lowered it and held and heard a slight click. Works now
Temperamental thing..lol
Cheers AB
Old Jun 22, 2005 | 10:01 AM
AquilaEagle's Avatar
Administrator
Ade, it does do this when disconnected. You have to reset it by doing (something like) the following
Wind all the way up, holding the switch all the way up for a few seconds after.
WInd all the way down again
Repeat.
Old Jun 22, 2005 | 11:34 PM
Spanners's Avatar
From the tech manual:
Resetting the power window unit
Resetting the power window control unit is required after performing the following procedures:
- shutdown of the battery power.
- shutdown of the electric power caused by both No. 17 (20 A) and No. 8 (20 A) fuses.
- open circuit caused by disconnected 14P connector from the power window master switch.
- remove of the regulator, glass or glass run channel.
1. Make sure the glass is installed properly.
2. Turn the ignition switch OFF.
3. Remove the No. 17 (20 A) fuse in the under-dash fuse/relay box.
4. Turn the ignition switch ON (II) and hold on for one second, then turn it OFF. Install the No. 17 (20 A) fuse in the under-dash fuse/relay box five seconds later after turning the ignition switch OFF.
5. Make sure the driver
Old Jun 22, 2005 | 11:38 PM
Spanners's Avatar
I would be curious to know if this procedure works. I had my battery replaced back in April and the car, of course, ended up without the auto lift function. I pressed up and down and pressed again in random sequences and eventually the auto function started to work again. Took maybe ten minutes of random pressing. Doubt I opened the door or started the engine though.
Old Jun 23, 2005 | 12:00 AM
Pie_n_Chips's Avatar
Ignition on, window down, window up and hold for approx 3-5 seconds -done, tis the way of all auto closure windows
Old Jun 23, 2005 | 01:09 AM
Spanners's Avatar
Tech manual says you have to start engine, open the door, whistle the Honda song wile wearing lacy underpants.
Old Jun 23, 2005 | 01:59 AM
Did Mike have an input in writting the manual (lacy underpants and all that)
