Ball joint splitter - lower wishbone
Remove the nut then screw it back on a couple of threads by hand (so as not to damage the threads if you miss), then if your a good aim whack the side of the wishbone where the pin pass's through or use a drift to to the same place, 2 or 3 good sharp well placed blows will do the job, sometimes when the taper release's you can hear the strike change note
That would be great, would I be able to borrow them tomorrow morning by any chance? Sorry it's very late notice but i've got the wishbones unbolted and completly overlooked the ball joints - doh!
Certainly, I will get them out of the garage 1st thing. I may be out but if so I will leave them in a bag by the door.
The smaller splitter works on most of the ball joints but there were a couple that I could only split with the bigger one.
Originally Posted by Floppy' timestamp='1339195860' post='21767046
A ball joint splitter is definitely the way to go. You don't want to risk breaking the ball joint with the cost of those particular ones!
