Basic injector fitting and cushions/o rings
Old Apr 17, 2012 | 07:15 AM
s2konroids's Avatar
Default Basic injector fitting and cushions/o rings
Hi guys,
I need to replace the injectors as the current ones flow rate it not enough, i have some RC650's to fit but can't remember the crack about o rings and cushon rings.
Heres a picture of them, is everything i need on the injectors?, what about the cushions that sit in the intake manifold, do you reuse them or are they on the end of the injector?
In the pics A is the O ring, and B, the bottom O ring does that sit in the intake manifold/injector hole or do i need a new cushion or use the stock ones?
I have small bag of rings too, just checking i have everything. Any fitting tips/method would be greatly appreciated.
Thanks
Old Apr 17, 2012 | 07:51 AM
MB's Avatar
MB
Member
Do you not need spacers for the rail to fit those?
Old Apr 17, 2012 | 07:52 AM
s2konroids's Avatar
Not sure mate.
Old Apr 17, 2012 | 08:00 AM
Kitesurfer s2000's Avatar
Yes you will 3 of them ,just get some washers that will do the trick
Old Apr 17, 2012 | 08:06 AM
s2konroids's Avatar
IIRC put washer under the stud then? 3 washer each stud?
Is it best to just remove the fuel rail with injectors in, i think the manual says remove the fule pulsation damper but you dont need to?
What about the cushions that are present in the intake manifold/injector holes do i need new ones or re-use stock?
CHeers
Old Apr 17, 2012 | 08:19 AM
MB's Avatar
MB
Member
Oem ones won't fit.
Old Apr 17, 2012 | 12:25 PM
nick300zx's Avatar
i just did this, as lee sed you will need spacers i also used 3 washers under each stud. i had to uses two o rings on the bottom to get them to fit propperly. did it with every thing still conected
Old Apr 17, 2012 | 12:27 PM
s2konroids's Avatar
Cheers Nick.
I take it you removed the OEM cushion from the injector hole/intake manifold and put two O rings on the bottom of the metal part?
Got any pics?
Old Apr 17, 2012 | 12:36 PM
I dident put mine in or out mate ,When are you ready to tune it .
Old Apr 17, 2012 | 12:37 PM
nick300zx's Avatar
Yep that's exactly what i did, sorry no pics i get to excited when im doing car bits and just want to get them done so forget about photos!
