Breakers yard for S2000 parts
Old Mar 2, 2023 | 07:05 AM
striggy's Avatar
Default Breakers yard for S2000 parts
Does anyone know of any breakers yards in the UK that may have parts for an S2000? I have been trying to get hold of a pair of lambda sensors for a while without much success.
Old Mar 2, 2023 | 07:52 AM
mysteryjedi's Avatar
These are available for a later car...
https://s2000power.co.uk/shop/used/h...old-fit-06-09/
https://s2000power.co.uk/shop/used/h...nly-for-06-09/
Old Mar 2, 2023 | 09:31 AM
Nottm_S2's Avatar
Buying used, not sure it's worth it. Just get a decent branded one new.
Failing that integrastella breaks lots of S2s
Old Mar 2, 2023 | 11:37 AM
baldspot_lol's Avatar
eurocarparts lists 3 for an ap1 including 2 universals and one direct fit for the rear sensor, ranging from £60 to £85 for the bosch version. unfortunatly only the 2 universals for an ap2.
IMHO not worth risking used to save £20-30, particularly for a service item.
Old Mar 2, 2023 | 01:19 PM
noodels's Avatar
Rockauto seem popular
A thought,,,back one doesnt do much tbh,only tells you cat is fcuk,most people with TP/HFC will space them to avoid flow and stop cell anyway
Old Mar 3, 2023 | 03:40 AM
WallaceS2K's Avatar
The rear sensor from Denso can be had cheap off amazon but comes from the US -
Denso 234-4601 Oxygen Sensor : Amazon.co.uk: Automotive Denso 234-4601 Oxygen Sensor : Amazon.co.uk: Automotive
Agreed it doesn't do anything though.
Old Mar 3, 2023 | 04:41 PM
aaronyuri's Avatar
You can get the 2006+ primary sensor from Autodoc: https://www.autodoc.co.uk/denso/16176165 | I bought and fitted this a few weeks ago - it is identical to the sensor that I removed (both branded Denso). DENSO DOX-0517 is what you're looking for if you want to shop around. I got mine for £123 delivered but looks like they have gone up in price now - £138 just for the sensor.
Not sure where to find a secondary for a 2006+ as I haven't looked into it.
Old Mar 7, 2023 | 09:51 AM
striggy's Avatar
Thanks for the tips all. I managed to get hold of a primary sensor from RockAuto. It is a Denzo one that I fitted; however, I am still getting the engine warning light with the same error code - P1157 --> P2A00 O2 sensor circuit range / Performance Bank 1 Sensor 1. I wonder if it is the sensor I have fitted and if the one from Autodoc (Denzo DOX-0517) will sort the issue?
Old Mar 7, 2023 | 01:20 PM
Nottm_S2's Avatar
Bank 1 should be the manifold one, if you replaced it and it still doesn't work dunno..
Old Mar 7, 2023 | 01:27 PM
aaronyuri's Avatar
What readings of mV do you get via OBD? It should be 0 for stoichiometric at idle. That error does suggest that the replacement sensor's output is still out of the expected range.
