Changing front brake discs
I'm attending a track day at Bruntingthorpe in a couple of weeks so thought i ought to replace my front discs which are pretty worn and have been doing some funny things recently. I bought a set from Brakes International and set about the task on Friday evening.
Took about an hour and a half to do both sides and was very straight forward. Excluding wheel nuts, you only have to undo a total of 6 bolts and screws per side. However, one piece of advice to anyone planning to do this job themselves. Do not attempt this job without an impact driver. You will not be able to undo the screws that locate the disc without one. I bought one in advance (only cost about
How much were the disks? Are they race items or fast road.
My car has about 35k on the clock and the front disks have a little rim on the side. The car will only be a weekend driver but I plan a nurburgring trip when it re-opens next year. It will probably be a good idea to get them done before then.
Did you replace the pads as well as the disks?
Originally Posted by simonprelude,Sep 12 2005, 09:22 AM
Impact driver or drill the screws out, alternatively copper slip on them when they are installed, they are only locating screws and only hold the disc in place when you take the wheel off.
Originally Posted by c_a_r_t_e_r,Sep 12 2005, 09:46 AM
Cheers for the tip, will be adding one to my tool collection!
RE the 6 bolts though - should you be using a torque wrench to do them back up? I always tend to overtighten everything...!
Oooh, I like the thought of converting hammering power into something more useful!
http://www.screwfix.com/app/sfd/cat/pro.js...=16735&ts=20705
