Check your diff mounts
Old Sep 9, 2016 | 10:54 PM
mikey_w50's Avatar
Default Check your diff mounts
Hi,
I know we are all on top of geo bushing etc on here. I had the car jacked up a few weeks back checking few things out and noticed two of my diff mounts were perished/torn. Worth having a look. Note I could only see mine were torn with wheels off the ground. With the car weight on the wheels the year is compressed and hidden.
Anyway cause I'm a top bloke I thought I'd pop it on here. Worth a look next time car is up. I changed mine over immediately. Car feels the exact same!!
Mike
Old Sep 12, 2016 | 05:41 AM
champion_hero's Avatar
Mike, where did you get these from? Honda want £480!
Old Sep 13, 2016 | 11:04 AM
mikey_w50's Avatar
I got innovative mounts from tegiwa for £160 for four. Car feels the exact same and lifetime guarantee. Tegiwa were also great to deal with. I use them for a lot of stuff.
Get the street versions and it's just same as stock.
Old Sep 13, 2016 | 11:19 AM
GreenmanS2000's Avatar
If the car feels the same after....was it worth replacing them?
Old Sep 13, 2016 | 02:05 PM
mikey_w50's Avatar
My mount was torn slightly so needed replaced.
I'd say if you were just upgrading then I wouldn't bother at all mate. If your current Honda ones are torn then worth thinking about rather than OEM.
Mine was only very slightly torn. I just replaced them all as precaution before tearing any more.
Old Sep 14, 2016 | 12:49 AM
Irish TuneR's Avatar
The two big rear ones are fluid filled (like the engine mounts) as well so they will starting leak once torn.
Old Sep 15, 2016 | 06:44 AM
That's a hell of a lot cheaper than the Honda ones. Did you replace them yourself?
Old Sep 16, 2016 | 02:16 AM
Richie2104's Avatar
My standard ones were torn & caused knocking when applied throttle. Had ran them torn for a while before this without issue though.
Ultimately did replace them with the Innovative 75a versions, as the Honda prices were crazy expensive.
S2Bray
Jun 25, 2021 03:09 AM
chris-stockton
Nov 21, 2014 10:43 AM
jowjeh
May 7, 2011 10:38 PM
s2000Junky
Oct 4, 2009 12:03 AM
