Checked your Throttle Cable recently?
Old Oct 19, 2009 | 01:05 PM
Wobbly's Avatar
Default Checked your Throttle Cable recently?
I have been working my way through the FAQ and carrying out a lot of the recomended work suggested within. The last thing I checked was the tension of the throttle cable, blimey it had about an inch of play in it! 2 minutes spannering later and it was adjusted to the suggested 1/4 inch and what a difference. Gear changes are smoother and the idle seems much steadier.
This is a classic example of one of those jobs that get overlooked and I only wish I had checked it earlier. Or is it just me that has been lazy?
Old Oct 19, 2009 | 01:20 PM
Squeak's Avatar
Thought mine was a bit slack. got it checked and yes a great difference
My car was so unresponsive before
Old Oct 19, 2009 | 01:56 PM
Ultra_Nexus's Avatar
This is something I always do on every Honda I work on.
Those who's S2000s I have worked on, please feel free to check
Old Oct 19, 2009 | 02:03 PM
GrittyShaker's Avatar
First "mod" I did. I always have a tug when the bonnet's open.
Old Oct 19, 2009 | 02:05 PM
MB's Avatar
MB
Member
Always a good check.
Guide in the FAQ!
Old Oct 20, 2009 | 12:16 AM
Rob88's Avatar
Cool. Something else for me to do with the car.
Old Oct 20, 2009 | 12:51 AM
andyds2k's Avatar
The throttle cable adjustment should not be effecting your idle. If it is then you may have taken too much slack out.
Old Oct 20, 2009 | 01:04 AM
MB's Avatar
MB
Member
Correct, unless it's too tight, as you say.
Most common is that it's slack.
It affects response when you pull away.
Old Oct 20, 2009 | 01:13 AM
Petrol-Head's Avatar
which FAQ does it come under, had a look but couldn't see it....i'm probably "bloke looking"....
Old Oct 20, 2009 | 01:30 AM
Rob88's Avatar
Main Faq at the top.
Do a text search on the page for Throttle.
It's about the 7th or 8th time it's used, and there's a link next to it to a page on the US part of the site where someone explains how to do it.
The pictures don't display for me, but that could be because of the office firewall.
