Clutch alignment tool
Old Apr 21, 2009 | 08:09 AM
doyler's Avatar
Question Clutch alignment tool
Hi all,
iv decided to go DIY as regards changing the clutch in my car.
took the old one out and there was a piece of metal floating around in it,there is like small metal ribs underneath the friction disc and it was one of them that broke off.It effected the car by making it difficult to shift into gears,but im guessing now thats because my clutche wasnt fully engaging.I thought my gearbox was wrecked so im somewhat relieved.
So far everything has gone good,as regards the procedure for removing the clutch, but as this is the first time to change a clutch in any car, iv hit a stump in the manual where it says i need to use a clutch alignment tool and remover handle, are these really necessary or is there any alternative to using these??
All hints and tips are welcome
Old Apr 21, 2009 | 08:20 AM
motogp1's Avatar
https://www.s2ki.com/forums/index.php?showt...post&p=14346841
Old Apr 21, 2009 | 08:28 AM
RISLAR's Avatar
Originally Posted by motogp1,Apr 21 2009, 05:20 PM
Beat me to it Richy .. PS you dont need the alignment tools, they are just to make it easier
Old Apr 21, 2009 | 08:34 AM
motogp1's Avatar
If mine ever goes i'm coming to see you steve.........
Old Apr 21, 2009 | 10:05 AM
doyler's Avatar
Yeah hats off to the write up rislar.Was just a little unsure to how you aligned it,So by eye or feel with a straight edge or somethin is good enough yeah??Unfortunatly i dont have the luxury of a lift,but ill manage none the less.
Go and check my valve clearance then
Old Apr 21, 2009 | 10:27 AM
Bibbs's Avatar
I bought one and it wasn't needed. I just felt round the edge when tightening the pressure plate.
It's a 1/2mm "lip" of overlap on the friction plate. Just feel it on the edges to make it centred and slowly do the bolts up.
Old Apr 21, 2009 | 10:31 AM
doyler's Avatar
Nice one,ill try that and see how i get on
Old Apr 21, 2009 | 10:49 AM
m1bjr's Avatar
In the 'old days' we used a socket extension bar and socket.
A luxury would be a busted gearbox you could extract the input shaft from for free at a breakers
Old Apr 22, 2009 | 08:00 AM
doyler's Avatar
just wondering,did any of yee check the runout on your flywheel to see if its within tolerance?? and also on my flywheel it is speckled with little dark spots, scorch marks from the heat i presume,is this normal??
Old Apr 22, 2009 | 08:11 AM
RISLAR's Avatar
I did, mine was shagged so replaced that on the second time around!!! I would check to be sure
Oh and the scorch marks are normal !
