clutch master cylinder?
Old Apr 25, 2010 | 08:33 AM
rwillis's Avatar
Default clutch master cylinder?
went to drive my s2000 out the garage today but it would not let me select any gear. checked clutch master cylinder level and it was a little below minimum. checked in driver footwell at the piston and noticed it was damp with black residue so i suspect its seals are leaking. I have topped it up but still the car will not go into gear...maybe air block? i am goin to bleed it and see if that makes any difference.
advice im after is:- cant you get a master cylinder repair kit/seals?
i know you can get a complete master cylinder from "hardtop guy" for around £100, does anyone know roughly how long it will take for postage? or alternativly anywhere else i can get 1 from?
thanks Rob
Old Apr 25, 2010 | 08:35 AM
loftust's Avatar
GarageR, a breaker/servicer/member on here should be able to sort you out
With postage from HTG...feck knows, he doesn't even respond to emails
Old Apr 25, 2010 | 08:50 AM
rwillis's Avatar
thanks for the quick reply, i have sent a pm to GarageR. and thanks for the headup about HTG as i dont want to be waiting weeks on end for it to show up
anybody else got any advice/views on where to get seals or clutch master cylinder?
Rob
Old Apr 25, 2010 | 08:58 AM
S2k Eire's Avatar
PM brentd2319 OEM parts from the states...
Old Apr 25, 2010 | 01:01 PM
m1bjr's Avatar
You can probably get one on eBay:
http://cgi.ebay.co.uk/Honda-S2000-master-c...413204002r12018
AZ-S2000
Sep 28, 2012 05:37 PM
stack
Nov 7, 2010 07:44 AM
Whitefire818
Nov 27, 2009 12:12 AM
heffergm
Mar 21, 2004 04:56 PM
