Clutch problem ?
Hi
Car has done 45K miles from new. Would a clutch go after this time ? Symptons are when accelerating the rev's go way up and only after a few seconds does the car respond. Any idea's ?
Thanks
Thanks
Sounds possible, usual test is to stick it in third gear with the handbrake applied and release the clutch gently, if the revs rise the clutch is suspect, it should stalltrying to drive against the brakes. HTH.
Sounds like its slipping to me...I had exactly that on my Corrado G60 a while back. Rev's would rise and then the car would start to pick up but not in line with the rev range. I also had it from time to time on my re-mapped E46 diesel, exactly the same symptoms.
as for your mileage worry you can burn a clutch out in a few hundred miles if you ride it like a granny so yes they can go at 45k or sooner.
mines had its clutch changed last year with 45k miles and im looking at fitting a uprated one this year as i have a six paddle plate in my boot i got free
