Clutch Relay?
Old Mar 26, 2007 | 06:39 AM
mikey k's Avatar
Not yet will do whilst I'm working on the electrics tonight!
Old Mar 26, 2007 | 02:00 PM
martin j's Avatar
Originally Posted by mikey k' date='Mar 26 2007, 12:46 AM
No your thinking of the Clutch Delay Valve on +04 which is an orifice plate in the clutch cylinder.
What does this delay valve do then,? apart from delay.
Old Mar 27, 2007 | 03:34 AM
mikey k's Avatar
It does what it says on the tin - stops a dumped clutch straining the drive train!
Old Mar 27, 2007 | 09:39 AM
barnabylee's Avatar
Just a wild guess here but it could be for the air conditioning compressor??
You could remove it and see if the A/C still works or what else doesn't!!
Old Mar 27, 2007 | 12:11 PM
martin j's Avatar
That seems to make sense.
Old Mar 27, 2007 | 12:22 PM
CocoPops's Avatar
So if you are constantly changing gear, the aircon won't work?!?
Old Mar 27, 2007 | 12:31 PM
ian's Avatar
ian
Controls the clutch on the front of air con compressor.
Old Mar 27, 2007 | 12:32 PM
MB's Avatar
MB
Member
No the AC is driven from the accessory drive belt, but it does have its own type of clutch which is used when you turn the AC on, to ensure it then gets driven drom the belt.
Matt15
Oct 1, 2010 06:10 PM
Hoenda
Feb 22, 2010 06:18 PM
MARTS2K
Jul 1, 2008 01:12 PM
dedonderosa
May 15, 2008 06:14 PM
cmn
Jan 18, 2007 01:08 PM
