Coilover / shock top mount
Old Feb 18, 2010 | 01:18 PM
Fatbloke's Avatar
Default Coilover / shock top mount
Can anyone tell me the correct torque setting for the suspension top mounts?
Thanks..........
Old Feb 18, 2010 | 01:25 PM
Fatbloke's Avatar
I knew you'd be first out of the blocks, Steve.
What will the forum do for tech data when you've gone???
Cheers.........
Old Feb 18, 2010 | 01:32 PM
E4RTH WORM JIM's Avatar
FT = fecking tight
That's what mine are set at
Old Feb 18, 2010 | 01:34 PM
chrisr111's Avatar
Front: 22 lbft / 29 Nm
Rear: 36 lbft / 49 Nm
Chris.
Old Feb 18, 2010 | 01:38 PM
m1bjr's Avatar
Turret top studs to body, front and rear (pair of studs):
All to 36lbs in my Honda ESM. I just checked.
My original estimate now deleted for thread technical accuracy.
Old Feb 18, 2010 | 01:43 PM
chrisr111's Avatar
Depends which bolts FB means.
The nuts that attach the top mount to the dampers are what I quoted.
The nuts that attach the top mount to the car are as Steve quoted.
Chris.
Old Feb 18, 2010 | 01:48 PM
Fatbloke's Avatar
Sorry, it's the nuts that attach the shocks to the car I needed to know.
Thanks all...........
Old Feb 18, 2010 | 01:51 PM
m1bjr's Avatar
Post
36lbs all of them then.
Piston nuts as Chris says... 22f 36r
Old Feb 19, 2010 | 08:28 AM
S2000Si's Avatar
Sorry FB.. forgot to look it up..
Old Feb 19, 2010 | 12:22 PM
Fatbloke's Avatar
No problem, Si. I didn't want to nag you so I went public
Did you get round to checking yours and if so, had they loosened off any?
Cheers.........
