Common leaking spot on s2000
Hi guys,
Just found out a leaking on my 04 S2000 F20C2 engine, please see below image:
I did some research on internet, it seems to be the common leaking spot, some ppl just ignore it.
Need some advice here
) Any one could explain the reason for this leaking please?
I got a small leakage from the TCT inspection hole after re-using the same seal. It the golden looking cap head style bolt in the front of the head just above the head gasket.
Needless to say I replaced it and now no leak.
please check this thread: https://www.s2ki.com/s2000/topic/782606-is-this-normal/
that's exactly what happens to my S, seems to be a common issue.
