Condensation inside
Old Nov 10, 2014 | 10:04 AM
  #31
richmc's Avatar
Originally Posted by noodels
Originally Posted by GreenmanS2000' timestamp='1415642154' post='23399866
What happens if you don't empty it in time....
you get wet pants
If it works like the Maplin ones the full LED comes on and it switches off before it wees itself.
Old Nov 10, 2014 | 11:35 AM
  #32
dennohue's Avatar
"If it works like the Maplin ones the full LED comes on and it switches off before it wees itself."
You are correct Rich. However you would have to be rather negligent to let it fill up!
Old Nov 24, 2014 | 02:05 PM
  #33
dennohue's Avatar
Originally Posted by dennohue
I think I have cracked this problem!
Like many members I cannot get the car in the garage (it's a modern house with the usual 'dinky' garage!), so it stays on the drive in all weathers. The resulting condensation during cold spells causes a very damp interior with water dripping from the soft top.
Lidl recently had a small dehumidifier on offer which runs, through a transformer, from the mains. I am able to run an extension lead from the garage with the transformer plugged in under the car, where it is sheltered.
I tried it out last week, and, although the weather has not been cold, the unit collected one and a half pints of water. I was amazed!
If you suffer from this problem give it a try. The dehumidifier cost just over £30.
If you can run a mains lead to the car, which you have to leave outside, this is the answer!
With the recent cold weather the inside of the car has remained bone dry. However, I have to check the unit regularly as I'm collecting over a pint a day.
Old Nov 25, 2014 | 12:03 AM
  #34
weatyGT's Avatar
Bag of rice, rechargable dehumidifier, jobs a gooden.... buying a hard to may also help.
Old Nov 25, 2014 | 06:01 AM
  #35
CDP's Avatar
CDP
Take a look at the reviews on this stuff
It is essentially cat litter in a sock! I've heard this is a good DIY solution, although I've not tried it myself. Seems legit.
desmond
Sep 18, 2007 08:59 AM
bjeong1381
Aug 3, 2006 12:38 PM
jmd2000
Sep 9, 2005 01:11 AM
Intrepid175
May 11, 2004 09:51 AM
S2KTerpNut
Jul 17, 2002 04:59 AM
