Constant whine from gearbox?
Old Nov 12, 2013 | 12:04 PM
Chris_D's Avatar
Default Constant whine from gearbox?
Hi,
I seem to have a constant whine from what i think is the gearbox. does not seem effect the way the box is working gear changes are all good etc not changed the fluid and not really sure when it was last done. If I put the car in neutral when moving the noise remains its a constant pitch and is always there.
Found a video on youtube with the exact noise
http://www.youtube.com/watch?v=X1YMcmJGNxc
Anyone any ideas??
I know there has been loads of threads on this but as i found a video with the exact sound thought it was worth a shot.
Thanks
Chris
Old Nov 12, 2013 | 11:17 PM
garylythgoe's Avatar
Sounds like the diff maybe?
Old Nov 13, 2013 | 12:13 AM
unclefester's Avatar
Agree on the diff - but you removed the rear shelf and the sound proofing - you're now sat in a biscuit tin with mechanical noisy stuff bolted to it and that will amplify any sounds and make them worse.
When was the diff fluid last changed?
Old Nov 13, 2013 | 01:40 AM
heymynameismark's Avatar
Another for diff and I agree with the above - removing sound deadening / trim will make the diff sound even louder
Old Nov 13, 2013 | 02:54 AM
jml's Avatar
jml
Now that's weird !
Old Nov 13, 2013 | 04:09 AM
Old Nov 13, 2013 | 09:19 AM
Chris_D's Avatar
Thanks for the response,
Don't actually know when the diff oil was last changed by the looks of the service records 2011.
Will get it Changed when I get access to my tools, problem is they are 250 miles away might change the gearbox oil at the same time.
Thanks
Chris
Old Nov 13, 2013 | 10:09 AM
CHIPPO's Avatar
Are you sure its not sitting in the passenger seat!
Old Nov 13, 2013 | 10:14 AM
Chris_D's Avatar
What the oil?
Old Nov 13, 2013 | 11:23 AM
CHIPPO's Avatar
I was thinking it might be the passenger making the noise , they do tend to whine a lot in my experiance
