Coolant does not circulate in engine!
Old Feb 20, 2006 | 11:46 AM
Priso's Avatar
Default Coolant does not circulate in engine!
Anyone had a similar problem to this?
Fitted an AEM V2 CAI yesterday, however after filling the coolant back up (bypass pipe requires it) I then started the engine and checked if all was ok, I then noticed the top pipe to the radiator gets very hot after a while when the bottom pipe didn't (no heat from heaters either), also cooling fan did not turn on due to the sensor being at the bottom of the rad where its cold.
Then emptied the coolant out and tried to do as in the workshop manual only I cannot find the bleed cap from the heater bypass tube (section 10-8), filled up and let air out of the other cap (the air bleed bolt next to corner of engine block) but did not circulate water.
Today I just dismantled the water pump and found that to in perfect condition so out of ideas.
Any ideas?
Andy
Old Feb 20, 2006 | 12:30 PM
Turtle's Avatar
There's only one bleed - the one on the end of the intake manifold. Make sure the heater temp is on full (and you've had the electrics on so the valve moves) then refill and bleed.
-Brian.
Old Feb 20, 2006 | 12:46 PM
MB's Avatar
MB
Member
You need to look at what you have altered when fitting the AEM. You havent fitted a vac line to one of the little coolant ones or anything? Its been a while since I took my airbox off so not sure if you have to fiddle with them.
Not kinked anything?
MB
Bevy
Oct 4, 2016 11:53 PM
-Matt
Jul 30, 2015 09:57 AM
-Matt
Jan 6, 2015 12:33 PM
9kscream
Nov 19, 2003 04:28 PM
7900S2k
Dec 23, 2002 06:33 AM
